of, first off lets talk about the spider...
i went down on saturday mornign hoping to catch the spider. my first idea was to capture it using my mums' dyson - not my idea, my mums
unfortunately as soon as i got the dyson close it ran back into the chassis.
so, Sunday i decided to attack it with the oxy/ac torch. for some reason one fo the guys down the barn had locked it up in his shed and was on holliday - so it was time to improvise - aracnophobia time
armed with a lighter and a can of carb cleaner i waited for the spider to poke her head out and gave it a good dose or two of carb cleaner. with the chassis rails on fire i blew out the excess flames and cleaned any other webs away. so next time i'm down there if there are new webs i know it failed.
ideally i could do with borrowing some body rollers to put the bus on its side and give it a once over with the torch. anyone have a set local to south wales/bristol area
without knowin gif the spider/ spiders were killed i was a little apprehensive to lie under the bus so i prepped the cab floor areas for the 10p piece patches it requires. also, with a twisted stainless wire brush i started getting rid of any rust bubbles and rust around the bench seat plates. by the time i did this there were so many little rust bubbles that i thought it would be worth just giving the whole floor a coat of primer before painting it white.
still waiting for my dads friend to dig out his spot welded for the inspection hatch to be finished. i'd prefer to spot weld this as it will be neater and with the picture frame being 3mm and the floor 1.5 it will make welding easier - so my dad says
NaFe
p.s. i also fitted my black porshe boxster S wheels - which have previously been fashioned by Nelly's fab bus.
