Cheers chaps...
ok, the wiring has been routed down the opposite side of the bus to normal due to the oil tank located where the battey usually is.
i have swapped the suspension and brakes so the new bus has the good stuff and the old bus has the US stuff..
i then decided to try and fit the engine as best as i could without having to cut the engine bay area up. with a NON-removable valance it meant packing the rear of the bus on blocks of wood (plenty of them) and then moving the engine into place. it was quite difficult getting the gearbox above the torsion bar tube due to the extra 2Cylinder length of the enigne and the fixed valance. but i managed it. then it was a matter of jacking up either side of the bus and removing the blocks one by one...
you can see that i need to cut a section out of the rear valance to clear the back box. this is what neil did when he had it - although he made the removable valance which i still have, but dont want to cut the chassis number out and cut around the engine bay.
here you can see there is plenty of room when the tinwear is not on the engine, so will modify the tinwear rather than modify the engine bay - again to try and keep the engine bay as OG as possible
so with the removable valance as a temp a drew where i needed to cut
Uploaded with
ImageShack.us
using a whopping disc cutter i cut straight through inner and outer valance
then i set about putting an inspection hatch in. was thinking about a T25 one, but in the end decided if i could cut the hole carefully enough with a 1mm disc cutter and a straight edge then what i cut out can also be used as the cover. so with the hole cut, a picture frame was made up of 3mmx50mm plate. this will be spot welded to the bus and then i will fix the lid to the picture frame with some bolts. my dad reccommended i use these things which fix in place in the same way a pop rivot works, but maintains a threaded m6 hole. i believe you drill a hole for the rivot, then using a special gun with a m6 bolt, torque it up. this then sucks the rivot up while maintaining the threaded hole, then at a certain torque swtiches into reverse and unscrews.
bit difficult to explain i will get some pictures next week. anyway this is it all mocked up
also started attacking the middle bench seat locating keys. cut this out to good metal and going to make a new one to go in its place.
have also made a temp fix to the lhd dash to accomodate 3 of the 5 porsche clocks in the aperture for the OG clocks. leaving 2 clocks 1 being oil and fuel level and the other being a time clock.
i made a cardboard template with only the cold air lever slot because i dont have heat exchangers..
this should keep you all going
