ok, so managed to get a alot of little things done last night.
handbrake cables fitted (minus the adjustment)
speedo cable
fitted brake servo, master cylinder
fitted brake pedal lever
shift rod that goes through the beam and conencts the main shifter rod to the gear knob.
fitted all new flexi brake hoses
fitted the fuel accumalator, fuel pump and fuel filter
rear brake hoses
front brake hoses
fuel pump, accumalator and filter moutned above gearbox (outside the engine bay)
i've replaced the fuel hose from the pump to the accumalator
i also started replacing the flexi hoses on the engine as some of these were kinked and must have been stopping the air flow - which wouldnt have helped the engine thats for sure. The trouble is, because its so tight i'm unsure how i'm going to route the hose without causing it to kink. i think i could really do with a silicon hose 45 degree elbow with i.d. about 16mm not sure where to get it from...any ideas?
i'm now awaiting delivery of track rod boots from megabug so i can replace the slipt ones and fit the settering arm from the steering box to the idler.
one question. i was trying to do up the fix track rod yesterday and when i tried bolting it up to the idler the ball joint was just spinning around inside...is there a way to bolt this up without it spinning or does it call for a new track rod? i've tried hammering the taper in to bit it but this didnt work.
