my god was it cold last night!!! i managed to see out a full session working on the barn. i'm glad for the massive draft that comes in during the summer months to cool me down, but wish the farmer would sort it out for the Winter
anyway, managed to tweek and trim the first bit of tinware i made last week. then when i was happy with the profile, welded up the slits, and sanded back:
my dad delivered some more sheet metal meaning that i could also make a start on the other side. so first job was to scrib onto the card where the vertical tin would met if it was tight againt the chassis. then i removed the card and inset the line by 28mm. this accounts for the 18mm distance that should be between the engine tin and the chassis + a 10mm lip that will be welded onto the engine tin for me to be able to use the stock foam.
so i removed the card and taped together
my dad folded me a piece of 1.5mm sheet by 180.20mm and 850 long which i marked, cut, slit and bent:
and offered into the space:
as you can can see in the last picture, the horizontal tin extends way past the piece i've trial fitted. this is the same on both sides. once both side are welded up i can trim this back. i was thinking bout keeping it as large as possible as i thought it may help to deflect extra heat from the engine bay, but Loxy pointed out it may just be somewhere where water can collect. what do you guys think??????
the piece in the last picture still needs some tweeking, but its pretty much there. once both are welded up , my dad siad he'd take them into work and TIG welde the 10mm tab on it as this would reduce the heat distortion. we are going to put a bigger tab on it to start which we will trim down - again to minimise the heat distortion.
once this is done, its on with the front and rear of the engine, but i must admit, i'm chuffed how its gone so far.
