Campmobile70
I have had a motor stripped down that came in a Bus from the U.S it was unfitted and unknown condition, it was not original to the bus, it had a wild buggy exhaust on it.
I believed it to be a stock 1600cc as it had a stock Solex carb and had mounts for bay engine bar, so must be a 1600 TP.
On expection it was a 2007cc with very low use, but sadly had been starved of oil and the bearings and barrels and pistons are kippered, (I don't know much tech talk so kippered is as technical as it gets
The barrels and piston maybe reusable but the guy who came to strip/inspect said best to replace.
The crank was balanced and I think he said it would be worth getting reground/balanced ( not 100% sure, it's a lot to take in when someone's firing loads of info at you and you haven't a clue about what they are telling you:-( he did say the crank would be 300-400 to buy, the heads looked all good, the case has had work on it to allow for the modified crank,looked like it could be reused.
The heads would be a few hundred each, I was told, not say I can sell them for that price but what the guy that stripped the motor told me???
Question is how much to replace bearings, re ground the ocrank and B&P, I know a big set of carbs would be needed but is this going to run into thousands?
Anyone interested in buying what I've got to build themselves a big motor
Ideas where to sell, it's completely stripped.
In Benfleet Essex
In Benfleet Essex
