D@VEY said:Got 2 sliding door handle bezels,Chrome U Bolt and chrome vent trims.
Might sell them on at the end of my rebuild as got doubles now.
moler said:You've made a cracking job of that roof 8)
scott wilson said:D@vey,
wow.Do you have much history with the bus.Also did it have the usa style rear reverse lights when you bare metalled it.If not did it have weird holes front and back about 6mm wide?
I ask as i believe you are restoring a genuine rhd deluxe sunroof model.I also believe that the paint colour is south african, however the m-codes say otherwise.Maybe an export collect on your holiday model! who knows.Now you have my intrest and as much help as you need
Scott
wibbler said:That was my worry, my main problem is at the top fronts which will be covered by the headlining, on the middle 2 ive managed to fit some smaller diameter pipe inside the steel pipe, the backs are fine but have fitted T pieces into the rubber to pick up the temporary pipes fom the front, works ok if you park up hill :lol:
