bluenose
Hi all,
Nothing is ever straight forward! trying to figure out the correct position of the accelerator cable tube through the fan shroud
Not sure why but there are two holes in the back (toward rear of the vehicle) of my fan shroud where the accelerator cable comes through. The tube was running through the top one in the pic below
The hole in the front of the fan shroud looks like it has been slightly butchered but anyway lines up with the top hole in the back.... but doesn't line up with the one in the tinware at all so the tube I took out is a bit of a dogs hind leg.
I'm thinking I need to drill another hole in the front of the fan shroud which would line up with the bottom hole in the rear of the fan shroud and the hole in the tinware or am I missing a trick?
Whatever I do the tube needs to run straight as I've brought one of these to make up for the whacking big spacer I have on the carb;
Do I need to plug up all these spares holes in the shroud?
