Alternative headlight bulbs?
Bears Dad
May 28, 2009
302
2
Buckinghamshire
Afternoon...
I’m looking to upgrade my headlight bulbs without faffing with fuses, wiring etc.
I was chatting to somebody at DATC and they recommended a halogen one but I can’t remember the full conversation (beer was involved).
This is what I’ve currently got:
The best option is to use adapter rings to convert to H4 bulbs then you can take advantage of the more efficient Osram nightbreaker/Phillips extreme bulbs.
But if your headlamp reflectors are tarnished you will not get the benefit of even the old tungsten bulbs.
https://www.ebay.co.uk/itm/2x-P45T-R2-H5-to-P43T-H4-BULB-ADAPTERS-OPEL-VW-RENAULT-VOLVO-BEETLE-PORSCHE/282431058041?hash=item41c233f079:g:wc8AAOSwfVhaAs1k
I think you can remove the beam shield caps which clip in front of the bulbs as modern bulbs have them built in.
Can someone confirm?
I did that and passed MOT. Can't remember which possibly both. Jk and Heritage sell halogen bulbs that pop straight in no issues with rewrite etc. I removed beam shields as the new bulbs come complete.
Yep that is true. If the bulb has a painted tip, then you don’t need the shields in place. They are to stop drivers from being dazzled by the exposed filament of the bulb.
I used these, but the ones Autocraft Engineering sell. They required a bit of tweaking with a Dremel, as firstly they wouldn’t fit into the reflector bowls, and then secondly, the bulb was rotated at the wrong angle. A bit of tweaking and they were all fitted snugly. Definitely worth doing, I went for some Philips bulbs that retain a slightly yellowish, period look, but are brighter than the normal offerings of a cheapo P45t bulb.
Bears Dad said:
I’m gonna have to get the Dremel on the bulb tabs as they’re stopping the plastic connector from fitting on the back.
Yep, I had to do the same! Just make sure that it will all still sit securely after cutting bits off - I’ll see if I’ve got the photos from when I did mine, but I had to have a good think about which bit to trim next.
