Some time ago, I purchased a couple of belts from one of the usual suspects to suit the alternator fitted to our van. When I went to fit one, I was surprised to find that it was so long that I could actually loop it over both pulleys whilst they were all bolted up. At the time, I didn’t do too much investigation and just purchased the same as what was fitted previously, and that has worked fine.
Anyway, fast forward to now and I thought I’d have another look. The original that fits is a Contitech 10x900 (albeit I pretty much have to move to just one or no shims as it breaks in, suggesting it is a little shorter than ideal). The new ones are branded JP Group 11.3x912. When I measured the outer length of both, I’ve found the Contitech is slightly undersized at 891mm and the JP is oversized at 922. This might explain why the fitment is so different.
So, does anyone have experience with similar, or could recommend a brand where the length is a bit closer to what it should be? I’d prefer to run an 11.3mm belt but don’t want to start a process of trial and error purchasing of different ones.
