as the alternator is a different length it needs a different mounting plate where it meets the shroud, or It would need the later fan shroud for the alternator.
and
And you will need a 912mm x 11.3mm fan belt (the generator uses a 905mm x 10mm belt). Both belts run in the same pulleys but the longer-wider belt runs a little higher in the grooves - you'll need to adjust the number of shims between the alternator pulley halves. It WILL work with the shorter thinner belt but that belt won't last - VW found they needed a stronger belt with the alternator equipped cars. To make it stronger it became wider and that means it rides higher in the grooves so it has to be longer too.
