bluenose said:made the isle of wight trip, bus ran like a gem and real happy with the conversion. Lorries and cross winds were no issue at all, could happily cruise along one handed.
It was a good test out for it as they don't have roads in the isle of wight just a series of giant pot holes so it took a good lashing. Everything stayed good and tight so I'm ticking this one off as job done now
PSG said:i just cant get my head round why a box would have zero backlash on the bench, but then have backlash when fitted. Does it have backlash when you take it off again? Is there some kind of strange linkage in the steering column or something?
I have been reading this for a while and following a few threads about it and its so strange.
Bundy said:I've fitted the new one to mine. I had to get a longer link bar to the rack as it just wouldn't fit right without. I also made my own version of the bracket to fit it as I couldn't get it to line up well enough...copied Simon's but used thicker steel and 4 bolts to hold it on. Had to change the angles a bit to make it all line up well, but my steering column is out of line to start with!
It's unbelievably nice to drive now without the huge play I had!
Let's hope these boxes last now...
Mags said:I got the longer shaft from Simon and tried to fit again a couple of weeks ago (I was going down to Cornwall so really wanted to get the Pailton box on) but still no joy. I just couldn't get the box to bolt up in a position that allowed the inner steering column to move freely and line up the 2 bolts on the plate at the bottom of the outer column inside the cab. I dropped Simon a mail just to let him know but I think I'm going to try and make up a new bracket and maybe trim off the bottom of the chassis leg to allow me to get the box flush with the leg. Although I don't want to do this I also don't want to bodge the mounting having the risk of something failing. The old style box I have now is OK, it got me around the south west for the past couple of weeks without problems, its certainly no worse than a steering box.
I'll try to get this done over the next few months.
One thing I wanted to ask others is how do you find the steering lock? It seems terrible to me but I don't know if that's because I've had 5 years of not driving the bus or the Red9 conversion has less lock?
Mags
Mags
