- Joined
- May 22, 2009
- Messages
- 519
- Reaction score
- 2
Has anyone changed the springs the std wishbone came with and interested to know how may clicks people are running at on the shocks? I've even driven mine yet but it seems rock hard.
Adjustable dampening??Mags said:Has anyone changed the springs the std wishbone came with and interested to know how may clicks people are running at on the shocks? I've even driven mine yet but it seems rock hard.
Mags said:Yep you are spot on, I took her out for an MOT yesterday and the ride is very good. Its the first time I have ever driven her with the Red 9 setup. The bad news was I have terrible play when changing direction, at the MOT we noticed the UJ's weren't as tight as they could be so I have tightened them up, but not been able to road test again. I spoke to Simon at Red 9 as I still think there is play in the bevel box, he was very helpful and offered to replace it if I still have a problem but I need to drive her again first to see if the UJ's were the problem.
bluenose said:is it the steering knocking when you turn the wheel or the suspension knocking when your cruising?
did you get the normal speal with the bevel box that you return it and they will check all the tolerances? I suspect they're just pumping the returns full of thicker grease and sending them back out.
The Type 25 box was the one they originally supplied the kit with but that had issues that the UJ between the column and the box was working at to tight an angle
bluenose said:not sure mine don't knock. Although the urethane bushes did squeak a lot, especially when new.
Did you mess with the spring adjustments or just the damping adjustment?
You'll have to get someone to jump up and down in it while you lie underneath and find the noise![]()
Mags said:Im hoping to let simon see my bus at Volksworld where he can see the play for himself.
