pkrboo said:So I am thinking about getting one of these for my Late bay. Is the tallest it can be setup drop wise is 3" ?? I assume the new bevel box is being sent out with new racks now?
Good news about the wheels,I want to keep my standard steelies, from a lowering perspective I have a 2.5" drop at the moment and don't want much more so it is the minimum drop I need which I think is 3" and it goes as low as 6.5" with adjustment on the shocks as well, if I have read correctly.Mags said:pkrboo said:So I am thinking about getting one of these for my Late bay. Is the tallest it can be setup drop wise is 3" ?? I assume the new bevel box is being sent out with new racks now?
Lowest drop is 6" according to the docs. I think I've got mine on the highest setting (or maybe one hole lower) and run stock wheels/tyres:
You need to ask Simon about the gearbox but I would assume you get the new type.
The main reason is for the steering rack tbh, a 3" drop isn't stock height, its still a fair drop but keeps my van drivable in 99.9% of circumstances.bluenose said:just out of interest why go for the red9 and run stock height?
although the red9 rides nice the stock setup is still more comfy
The bracket is steel, its just zinc coated so looks ali.bluenose said:Well done dude, great with this bevel box isn't it, did u notice if the bracket is steel or ali?
If your a bit close on the column binding has the floor been replaced at some point? Or maybe u could open up the holes in the base plate a little to move it forward some. I think a PO did this on mine as the holes were massive so I had plenty adjustment to centre the column
I think the tie rod ends are just standard t25 ones. I haven't checked if my boots are okay but have noted you can only get the nut on them by about two threads and doesn't reach the nylon
