Battery Charger
gagvanman
Oct 24, 2011
540
115
Grantham
Does anyone else have this problem?
Both my starter and leisure batteries are connected to a Durite split charger system which works fine. However, my tracker runs down the leisure battery if the van isn't used for a week or so. I use a Ctek battery charger to recharge, but the Ctek throws up an error and does not charge the battery. When the Durite is disconnected, the battery charger works fine??
Thanks...
https://www.12voltplanet.co.uk/split-charging.html
Sent from my SM-G975F using Tapatalk
Sounds like a faulty relay or it's not set to cut off at the right voltage, I know they can be adjusted
