So one of the many little projects I’ve been working on has been the pop top roof.
The one currently fitted to the Bay is painted with a black bitumen rubberised paint, not that it shows any signs of leaking.
I was in a local garage a few months back and spotted a VW pop top roof wedged in the corner of their workshop taking up space.
Turns out it had been there ages and they didn’t know what to do with it.
Did a deal and brought it home on the roof of the Disco!
Gave it a blast with the pressure washer and it cleaned up ok.
It was a solid top, same as mine and in decent shape.
I’ve set about cleaning it up.
Took everything off the top and sanded it back to bare metal and primer
Removed the bellows if anyone needs some?!
Cleaned it all off and then got it inside.
Once upside down I removed the polystyrene that was stuck to it
Then took it back outside and used an angle grinder and sander again to smooth out any adhesive that was left.
Then hoovered and cleaned it all with panel wipe.
Next was removing the metal work (which I’m going to sand blast and powder coat)
Then a visit to my local magical nut and bolt place to source all stainless steel replacements.
Then a layer of Dodo mat Pro sound deadening.
That’s about where I’ve got to!
Next is paint the outside.
Let that dry.
Fit the roof vent.
Turn it back over and finish the interior insulation and roof panel.
More images to follow
