- Joined
- Jul 5, 2021
- Messages
- 489
- Reaction score
- 272
Thanks!Nice rack sir
I have one on the garage - came with the van - will one day sort it out. Goes on the rear part of the roof as not much space at the front
Thanks Mike!great work!
Nothing wrong with slow progress. I get one day a week (if I'm lucky!) on my bus - and even then progress can be hampered due to having to adapt badly fitting parts etcThanks Mike!
Slowly getting there!
Not 100% sure I would believe what you are being told about the twin 40's, did they fit them or are the secondhand?, what they mean is the floats are stuck allowing petrol to syphon through, so are they talking about the needle valves?Interesting day today!
I got the bus back - which is great!
First time I’ve driven it since early January….
Good bits:
Newly fitted refurb’d steering box = brilliant!
Rebuilt brakes = brilliant! Such a difference!
Rear roof metal work - all done, the bus is watertight and the metal work looks to have been done well.
Not so good bits….
The bus is full of dust and dirt, as is the engine bay. Going to need a decent clean.
The newly sprayed green on the rear quarter isn’t a perfect match. And I know that’s going to bother me!
Bad bits….
Broke down on the way home. Managed to get back eventually but far from ideal.
So I phoned the VW Engine company for advice, as it’s a new engine from them.
They were helpful straight away.
Apparently they’ve recently found issues with the Weber twin 40 carbs on engines that haven’t been driven much for a while. Which are causing them to stay open and therefore flood the fuel through. Furring up the needles.
This was causing my engine to run lumpy, cut out and backfire.
They’ve got me to drain the oil out and clamp the main fuel line.
The bus needs to go back to them for them to strip the carbs and fit an electric fuel cutoff.
They can do my run in 500 mile service at the same time.
So going to need to get it on a low loader which is another cost I don’t need.
But - also means I’ve missed the slot I had booked with a trimmers to finish off the interior panels
Frustrating day of mixed emotions today!
