Buttys bits
Job done, really easy to fit. Makes a huge difference to pedal feel as already stated by everyone. Fitted seals to my brake and clutch pedals while I was there too.
butty said:
Just remember do not clamp the cable . Nip up then back off half a turn or you will break cables . It's meant to swivel/rotate . Cheers for the feedback guys .
Yeah I figured it out. My cable was also rubbing along the chassis where it passes through one of the crossmembers, so I have stuck some plastic tube around it.
Today I fitted my Buttys Bits throttle kit that I purchased at Aircooled 14. :mrgreen:
Dead easy to fit.
Great bit of kit... No sticker though! :lol: Maybe if I ask nicely! 8)
Cool. 8)
Paranoid now as to whether I have fitted the linkage correctly?
http://s911.photobucket.com/user/gas1man/media/20140704_193808_zpsa9b7dd42.jpg.html" onclick="window.open(this.href);return false;
http://s911.photobucket.com/user/gas1man/media/20140704_193702_zpsa3fb9f5a.jpg.html" onclick="window.open(this.href);return false;
Please set this mind at rest, either way.
Thanks again.
J & P
:D :D :D
Yours is a rhd the one above is a lhd hence the difference .
Do you find the swivel section touches the chassis rail ? If it does you can mount the long rod on the opposite side of the swivel section .
Thanks again.
J & P
:D :D :D
Thank you Butty, just as I thought.
Still works like a charm. Will adjust.
J & P
:D :D :D
Even more travel now , perfect. :D
Sticker to prove with a " did you put those there?" answer YES (proudly)
Just fitted mine (rhd crossover one) went together easily and has made a big improvement, oh and i got a sticker :msn4: Cheers butty!
