Gabs
- Joined
- Jun 1, 2023
- Messages
- 96
- Reaction score
- 69
- Location
- Bristol
- Year of Your Van(s)
- 1970
- Van Type
- T2 a
After some help as I have a backfire/pop coming through my LH carb and runs flat at 2000rpm especially when I hit the inclined roads. I have replaced all plugs, leads with cap rotor arm and just cleaned LH carb as seen some info on an idle jet block. It runs nice on tickover but when you blip throttle it backfires on that LH carb. Don’t seem to have an air leak as sprayed all around inlet and no change in engine note.
Should I re-check valve clearance on LH bank ?
I will take the plugs out and check again.
Any help appreciated please.
