89Rallye
Last one of the week from me and a quick one so you can breathe a sigh of relief,
Wired the battery up and frigged the ignition (no keys) to see what would happen, no smoke or flames! So it was a start
So the run down..
Good bits,
Ignition light - check
Oil pressure light - check (and working)
Headlights - check
High beam including dash light - check
The Issues,
Hazard lights - intermittent operation and only o/s/f & n/s/r working no dash lights
Indicators (column switch) not working at all
Side lights not working all round (yet dash light working)
Wipers not working
Fuel gauge not working - showing full
Interior lights not working (not the end of the world but if it's there it should work s my motto)
So all in all not bad, I think I'm going to have to drop the dash out which I really didn't want to do but it needs a good scrubbing and it'll make life easier getting into the fusebox.
I had a quick look at the flasher unit, might of found the intermittent fault :lol:
This didn't look good
So out came the soldering iron,
Refitted and hey presto hazards are working (yes I did take about 6 photos. To get this :lol: ), although the n/s/f light unit had a broken clip which needed sorting. And the rears still arnt right but I think this is an earth fault because I painted the lamps.
All dash lights working now too 8)
Cut a load of dead wiring out, including a key switch which had fallen behind the front panel. So it's not looking good for the ignition switch (who ever it was pm'd me about a new ignition switch unit feel free to. Say I told you so!)
Also had the engine running in the van momentarily but it didn't last wrong as I think there's not enough fuel in the tank.
So the run down..
Good bits,
Headlights - check
The Issues,
Wipers not working
