Seamus1982
- Joined
- Apr 29, 2010
- Messages
- 131
- Reaction score
- 0
More clutch woes!
Following on from an earlier issue, where I had the release bearing sleeve fitted with an early clutch plate, I replaced the full clutch assembly with an LUK early style. - https://www.heritagepartscentre.com/uk/111198141xluk-200mm-clutch-kit-with-centre-pad-for-1500-1600.html?gclid=CjwKCAjw1K75BRAEEiwAd41h1InYTM7-CWw75xw0Zl_1XXtk2FvpPaZ5l2QIdoBIBZWBAWDvRwphVhoCbW8QAvD_BwE
So, I fitted the clutch using the locating tool I purchased. Replaced the bearing forks, bearing and pins, put everything back together.
All runs fine, however when I depress the clutch pedal I can hear a slight whirring noise, not very loud at all and can't really be heard outside the cabin. However if I keep the clutch depressed, it does turn to a squeal. No clunks, no mechanical sounds, just a high pitched squeal.
I have looked into it and some possible issues;
Bearing misaligned due to bent fork - new forks but still possible
Issue with bearing - again new but possible
The clutch plate, pressure plate, bearing and springs all came as part of the system, so really should be ok running with each other.
What I was wondering though, is could this just be a clutch cable adjustment issue? I can't seem to see much on this in a forum search.
My thinking is that the clutch isn't fully disengaging, therefore partly rubbing on the flywheel, causing the squeal. Is this possible?
Thanks in advance for any advice! Still learning everyday with the van!
