I've bought a scat Std size billet pulley to replace the existing scat one that was rather rough .The new one came with a split shim type washer which is apparently to be used if you need to line your top and bottom pulleys up .
After removing the old Scat pulley I could see that there was no split washer in place ,and although I don't think my pulley alignment is way out I had been getting some rubbing /noise from the tin behind the pulley which was rubbing on the back .If I use this spacer I think it will eliminate that but I wasn't sure if that would mess any belt alignment up?
Also I'm trying to remove the inner half of the Dynamo pulley to fit a new billet one but I can't seem to budge it .Are they just normally rusted on ?
