Hi All
I have a metallic creak coming from the rear beam , seems to be (in) behind the rear spring plate cover OSR,happens after bumps and randomly , shocks seems ok and shock bushes , when lying underneath i got a friend to rock the van side to side and pretty sure the creak is coming from that point .
Friend has suggested its probably the spring plate bush ? , does this sound about right ? should i replace both sides ? is there a special lube :shock: that should be used ? How desperate is it ? is it likely to do damage if I'm driving it , can i leave it till after VolksWorld ?
71 ( oct 70 ) panel , stock height and suspension .
Many thanks
Chico
Many thanks
Chico
