curtain track round sliding door ???
davebug
Jun 18, 2009
683
skeg vegas
Soon looking at fitting curtain tracks,think going for silet gliss but bit stumped on how to get around the sliding door ?Any suggestions very welcome and thanks !! :)
i just fitted mine a little higher, then when the doors shut, i took it into the curtain wire thingy i fitted to the door under the window.
i also fitted the rail under the sun visors that way when there shut i fold down the sun visor and it keeps the curtain tight. Then just finished either side of the rear view mirror. Hope this helps
ash
dubscum said:
I also over lapped the rail above the sliding door quite alot to go over the bit that sticks out the cover the hinge
that looks a good plan bud ,shall prob take the same route ,thanks D... :)
As the bus is just outside heres a close-up of the curtain track following the contour of the slider as in Ob-1's bus ^^^^^
Jee mate that looks like a difficult bit of bendage there,how the .... do you do that ????? :shock:
I think all Devon's have the curtain track in that position, they could have shaped it on a former with a bit of heat
i asked a mate who had fixed his and he said bend it round, was not 100% sure and did want the curtain the stick out to much, so added the rail higher and longer, works a treat just make sure your curtains are long enough
