Hope someone may have some they can check sizes for me. I have a set that should be for a late bay but don,t fit wondering if they may be for the early set up.
If anyone could check a couple of sizes so I can compare that would be great.
I need 1. Overall diameter of the splash plate.
2. With plate sat flat on large outer edge height to underside of mounting face I.e. the offset.
I will check mine later and post them to compare.
Thanks. Mark
Ok original 285mm dia. Height 30mm. With an offset to fit spindle of 18mm.
Replacements 325 dia. Height 30mm with only 8mm offset..
I,m thinking this is due to the different callipers used on the early dis brake setup.
Any help much appreciated.
Thanks. Mark
