Olly the Ozbus
- Joined
- May 11, 2008
- Messages
- 163
- Reaction score
- 0
...and where do I start my search :mrgreen:
Ello folks,
Bus has been running sweet all year but on my last big trip the old boy developed the following symptoms:
1: wandering idle (and sometimes so low it cuts out- although unable to adjust with the bypass screw)
2: cutting out when coming to a stop from high speed
3: pinking when descending steep hills on zero throttle
4: revs return very slowly to idle after blipping throttle
5: no longer able to adjust idle properly with the bypass screw
Just wondering if these are the symptoms of an airleak in the inlet manifold system as I've had a spraw of wd40 on the usual places (carb/manifold gasket, twinport rubber seals and manifold/head area) to see if the revs rise but they don't seem to.............I do have a servo but the leak doesn't seem to be at the manifold end or the non-return valve although I haven't checked at the servo end yet.
I wondered if it could be a problem with air leaking in past the bypass screw if the threads are worn- is this poss? Everything else (tappets, timing, carb tuning) should be fine but are there other things i should be looking for- I've seen mention of problems with the idle circuit in solex carbs so would it be worth blasting it with some carb cleaner down the top?!"
Ultimately some dellorto 36's are on the list but I'd like to get to the bottom of this in the mean time, especially if it has the tendency to run lean
Blimey, that is some rambling! Blame the vino and a long week but thanks oracle and hopefully I'll be getting my hands dirty this weekend :mrgreen:
ttfn
Olly
Ello folks,
ttfn
Olly
