empi Trigger Shifter help
markofkent
Sep 10, 2014
46
Rochester / Kent
I've installed a new empi Trigger Shifter
When I change from reverse back to 1st I struggle to find 1st
When going from 3rd - 2nd it can go straight into reverse without lifting the trigger
also when it is in any gear the stick can me moved left to right for about 4-5 inches
any help appreciated thx
Mark
I fitted my shifter and had to undo the bolts at the base move it forward or back until i found the sweet spot. It really is trial and error.Not much help but that's what i did.
Ive tried both spacers.......
the main problem seems to be 1st and then 3rd to 2nd :-(
3rd to 2nd it goes to reverse almost every time
Rough rule of thumb is put it into 2nd gear, slacken off the bolts, move the base of the shifter as far to the right (offside) as you can and hold it there while doing the bolts up, that should mean you can only get reverse while lifting the trigger. Is it new or used?
Its New Sidev
