Why do these things always happen a few days before a family holiday?!
So ... I thought I'd successfully dropped the engine out of my 72 crossover, repaired leaky petrol tank breathers and replaced the engine but unfortunately my dipstick temp gauge now reads a pretty constant 110-120 deg C, whereas before it was around 90.
Engine running just fine - power as before, if anything a little smoother and enough grunt to top 70mph two-up which seems OK.
Can't think what I've messed up but here's a little list of jobs that got done at the same time. Hopefully I've cocked up something obvious as I don't think I've time to take the engine out again.
1. petrol tank breathers connected up to oil bath air filter whereas previously they vented into engine bay... Could this be making it slightly richer? Surely marginal...
2. engine oil/strainer/gaskets replaced - 20W50 oil as before
3. rocker covers changed from SCAT to stock along with new gaskets in an attempt to solve leaks
4. valve clearances all adjusted back to 6 thou - a couple were on the tight side. Just possible I've erred on the side of caution here.
5. new foam seal round tinware
6. one new aluminium air hose as I tore one taking it off
7. new pertronix igniter as I managed to fry the old one (yes, it's true, they burn out instantly if you connect them up the wrong way round). Hmmm, wonder if I need to reset the timing even if all I did was drop a new pickup in the dizzy in the same mounting? But if the timing was wrong the bus wouldn't be pulling right, like it is, would it?
8. installed split charge relay and leisure battery
9. put some sound proofing above the engine and in front of the petrol tank
Was really hoping to get the family + camping gear to North Devon on Friday but unless I can solve this pronto I'm going to have to cave in and go in the Volvo + trailer
So, come on, what have I missed?!!! And no, I can't see any bits of tinware lying around that I've forgotten to replace! (Although I have to admit I may be going crazy and imagining it was complete when I'm sure it wasn't quite...)
Another question: should I notice poorer performance as it's running hotter? Could it just be the temp sender's changed?
Things I suppose I'll try tomorrow:
1. remove petrol breather from air intake
2. check the foam seal again...
3. check the temp sender is working properly with a kettle
4. pray harder
Dan
4. pray harder
Dan
