Engine Build Question
mr scoops
May 8, 2010
1,144
So, I'm getting together all the bits to build a ‘warm’ 1584cc engine for SuperDry. The idea is that I build the engine and literally take one out, put one in and fire her up.
See the old engine and use the money to get a Freeway Flier gearbox. I’ve got a lot of the stuff and I’ve got an idea of what’s left to buy, BUT, what have I forgotten?
I need EVERYTHING to build an engine as I want to sell the engine in the bus now as a total turnkey unit minus the exhaust.
So, any advice from anyone?? I know there’s a few people on here who have built their own engines up from scratch.
What lubes do I need to build?
Stuff I have already
·         Crankcase  (needs to be stripped of all studs etc and media blasted)
·         Crank
·         Conrods
·         Pistons & Barrels
·         Scat C25 Cam and Wheel
·         Bottom Pulley
·         Flywheel
·         1.25/1 Rocker Assy
·         Pertronix Dizzy and Ignition
·         HD Oil Pump
·         CB Los Banditos Heads
·         Weber 34 ICT Carbs, manifolds and Linkage
·         External Oil Cooler and Fan
·         External Oil Filter
·         Braided Oil Hosing
·         CB Adjustable Pushrod tubes
·         SCAT Rocker Covers
·         Bugpack Breather Kit
·         Clutch Plate
·         Alt Stand
·         Gaskets
·         Autometer Oil Temp and Pressure Gauges with Senders
·         Autometer Volt-meter
Stuff I still need to buy.
·         HD Cam Followers
·         Full set of Bearings
·         Pushrods
·         Tinware
·         SCAT Rocker Cover Clips
·         Crank case studs/bolts/nuts
·         Electric fuel pump
·         Fuel regulator
·         Heat Exchangers
·         Pertronix Coil
·         Ign Leads
·         Alternator
·         Sump Drain Plug
·         Billet Lead Clamps
·         Oil Filler Cap
·         Additional Dowels for Flywheel
shims to set the fly wheels end play or "float" and im guessing alternator pulley?? belt?? alternator strap? dipstick?? tinware screws? maybe hardware kit lol im jus goin off the top of my head it may help you remember some silly crap i know its a pain in ass buying all the stuff you need
