Matt Maz
Hi, I hope somebody can point me in the right direction
I took the van out for the first time since November and have had a couple of issues
Firstly, after filling up with fuel I had an awful smell of fuel inside the cab, which appears to have been when I had my old Danbury interior fitted....it seems as though the guy screwed the rear batton onto the rear bulkhead and went straight into the fuel tank :evil: Having taken the interior out obviously I am now getting the smell of fuel.....luckily I didn't fill the tank right up :shock:
What would be the best way to solve this??
The worst problem that I have is a really bad hesitation/spluttering/no power at around 40-60mph.
The engine is a 1600tp with Solex carb and oil bath filter and 009. The engine idles and starts fine with no problems whatsoever. It goes through the gears all ok but as soon as I am on an open road the engine will start to hesitate and the whole van will shake. I have tried driving through it however there is no power to accelerate. I then came to a stop and the engine died completley. It started up again straight away and idled ok. I gave the engine some rev's while stationary and it was fine.
I went on my way and exactly the same thing again :?: As soon as I got to a built up area at lower speeds it seemed ok :?:
The van was serviced in October last year and had new plugs, leads, roter, distributor cap, points checked and timing set.
Does anybody have any ideas of what to check? It seems to me like fuel isseue. I have checked for leaks but cannot see any.
Matt
Matt
