Elliott99
Hi Guys,
Hoping someone can suggest what to do next?
I have a 1970 T2 with a just run in 1776 engine, twin IDF 40s,and Vintage Speed exhaust.
Symptoms: continuous sporadic low popping noises from the exhaust, just audible between the firings. A really loud backfire one or two seconds after I turn her off. The exhaust smells as if its running rich, and is coloured black. However, the colour of the plugs says the mixture is exactly right.
I suspect that unburnt fuel is getting through to the exhaust, and today did a leak down test which gave 1 and 3 showing 20% leakage, and 2 and 4 showing 10%, which I believe is a pretty good result.
You can just hear the popping noises in the video if you listen hard.
Any ideas on what to do next please?
Elliott.
[photobucket] [/photobucket]
Elliott.
