Engine upgrade with AA 88mm pistons??
Stevec
Oct 14, 2012
315
Kenley Surrey
Hi
I'm thinking of upgrading my enginer but going for a 1700cc with slide in 88mm pistons and 90.5/92mm cylinder heads, has anyone done this set up or had experience with AA Performance Products?
Here's the write up for the set up
http://www.aircooled.net/1800cc-vw-engine-no-machine-combo/" onclick="window.open(this.href);return false;
Any input would be appreciated
Steve
Hi Steve
I have used and sold LOTS of the AA B&P kits and they are great value.
I presume you have a 1600cc engine.
You will be able to go for 1641cc very easily without modifying the cylinder heads or cases. This uses the 87mm piston and barrel kits:
https://www.vwheritage.com/vw_spares_Barrel-Piston-kit-1641cc-87mmx69mm-Repro-AC198870R_act_shop.product_pID_19649725.htm" onclick="window.open(this.href);return false;
You wont be able to run 90.5mm heads on 88mm B&P's. The 88mm piston and barels have a stock sized outer bore. 90.5mm are larger.
Anything further will require some machine to your case and cylinder heads.
Do feel free to give me a call or email if you want to talk through this further:
01273 444 000
[email protected]
Hope this helps
Alex
Hi Steve
Yes lots of people fit the 87mm 1641cc B&P's
I think it's the confusion of your questions versus the article you posted.
I have very rarely heard of people using the 87mm to 90.5mm B&P's that they talk of in the article that makes a 1679cc, mainly due to the fact that if you go down this route you need to either have your stock cylinder heads machined or buy a new pair of cylinder heads.
Hope that helps.
Alex
