FBH fuel tank location…
I have now installed my heater under the R&R, it fits perfectly (luckily just misses the R&R brace by about 1mm!), tomorrow I'll install the fuel tank behind the passenger seat and route the fuel line. Any advice as to how to do this? I'm guessing it's through a hole to under the bus then attach to diesel intake on heater, which is under the bus. 20241117_165030.jpg
I have now installed my heater under the R&R, it fits perfectly (luckily just misses the R&R brace by about 1mm!), tomorrow I'll install the fuel tank behind the passenger seat and route the fuel line. Any advice as to how to do this? I'm guessing it's through a hole to under the bus then attach to diesel intake on heater, which is under the bus..
That’s exactly my plan too , except I’m gonna try and get mine under the passenger seat. Does seem a little crazy that I’m having the tank behind the passenger seat and the heater under it too then have the diesel pipe go through the floor and back up again. But if that joint leaks, it’ll leak outside I guess. I might end up doing what you is doing and Chuck it under the bed because I’m getting a bit pi55y with it now.
Ozziedog,,,,,,,,,,,hopefully never use it :)
