Rippers
OK finally got to drive my bay for the first time today after getting it registered.
It seems to go ok, brakes are a lot better then I expected but the engine needs attention if you guys can help please! as i'm desperate to get to Brighton Breeze this weekend in it.
The engine is anything form a 1600-1776cc I was told it had a 1776 but I have my suspicions it not, its running a single weber carb and standard exhaust
1. First issue is that the carb seems to spit/pop when coasting, ie rolling down a hill with clutch down or when breaking from speed clutch down.
2. Second issue is that it stalls when stopping from speed, ie from 30mph to 5mph for a junction, It re starts each time. I'm wondering if it is idling too low? Its a Weber DFAV 32/36 can anyone give me an idiots guide on setting up the idle please.
3. There is an oil leak underneath engine towards the front where it joins the gearbox. I changed the flywheel oil seal and o-ring but its still leaking, push rods tubes look dry, there does seem to be a bit of oil leak from the big crank pulley dripping down and after the first journey it looks like some may have been flicked up the side of the tin ware. So other then the crank pulley oil seal are there any other areas prone to leak oil from on the engine? Do they/can they leak through the case join?
Lastly what oil do you guys recommend ? and which gearbox oil? I read somewhere EP80 is the one to go for?
Thanks hope you guys can help me out.. oh and it there is anyone local to me in Cheshunt Herts who fancies coming around and helping me you'd be more then welcome
