Resto-raider
Hi guys,
While I was at busfest this weekend I bought an R&R bed from Rusty Lee. I read that they are great quality and easy to fit.
Momentarily I am having some some trouble with the 'easy' part. Since everybody else fits these in 10 minutes i'm probably a dumbass. Maybe you can help me on my way because I'm ready to give up.
I didn't realise the angled mount had to be fitted onto the original seatbelt mounts because they are covered with bitumen mats in my van and nobody told me I could use the original mounting points so I aligned the angled brackets on the wheel arch, drilled holes and bolted it on. Perfect...until I made a bed out of it. It wasn't level and did not lign up with the cargo area above the engine.
Clearly I was doing something wrong, so via some forums I found out that it should be bolted in the original seatbelt mounting holes. However when I do this the square frame that should be bolted onto the floor dangles almost 2 inches from the floor and the floor is already raised with a wooden laminate floor.
If i lower the square frame to the floor the bracket doesn't line up with the arch and can't be bolted on.
Am I the only dumbass that doesn't get it?
Any idea what i'm doing wrong?
I already contacted Rusty Lee, but I was hoping someone could help me a bit sooner.
Some pics to go with the story;
The way I bolted it in the bed wasn't level and wouldn't line up.
Tried bolting it to the seatbelt mounting holes but then the frame is way too high above the floor. More than two inches!
When I lower the square frame to the floor the angled bracket doesn't line up with the wheel arch and leaves a gap of about an inch. You can see the lower hole that I drilled but also the original seatbelt mounting hole.
I appreciate your help.
Rick
Rick
