I’ve got an oil leak on my fuel pump so I started changing it yesterday, but half the bloomin plastic has snapped inside. I’m gonna tap thread it and put a bolt in to try and pull it out. Is that the best way to get it out and should I put any kind of lubricant down to help.
Secondly, there was no gaskets used, just some seal. Should I put gaskets on the new one or put it back the way it was when it worked fine. Just thinking the gaskets will raise the pump slightly won’t they, meaning the rod won’t hit the pump mechanism as it did?
71’ with standard engine
