Time to deal with the front wheel arch and floor panel...
Ready for the front wheel arch .The floor panel is only stood in place at this time.
Ready for closing panel at rear of arch
Bit of protection for that new floor support !! ( seems like a lifetime ago that the floor, 6 new floor supports and
4 jacking points went in )
Closing panel offered up
Arch on.. ( those two little words will never justify the aggro getting the 'kin thing to line up !!)
Little repair needed between arch and floor
And from inside
Ready for the floor panel
Welded in place
'Prettied' up and etch primed
The nearside arch has been on for yonks now and I don't seem to have many photo's.
Pretty much the same as the offside really so here's the couple I have...
Arch and closing panel in.
Another session of open wallet surgery won me the US door in primer.
It came with an opening quarter so I'm not complaining. Now got both doors from USA, both
with opening quarters... result !
Primed, ready for paint, stonechip etc..
The only problem with the new wheel arches , ...OTHER THAN you needing a trolley jack,
bottle jack, shit loads of 2" x 2" timber struts and wedges, 2 ratchet straps,
an 8" bolt (temporary) a large hammer, and a lot of grunting,......... is that they don't
come with the 'sticky out' bit of metal where the arch meets the front panel......
So the appropriate thickness of metal was sourced ( when I say 'sourced' I mean I
cut the end off the spanner for my 9"" disc cutter, cut it into two pieces )
and positioned it to look a bit more like the original......
They both need a bit more grinding down and shaping but I'm not sure of the size and angle till I can look at an original one !
Oh.... finally remembered to plate the holes in the new floor !!
Still can't work out WTF they were for.
Be back soon with some more photo's, one more post and I should be up to date !!!!
