the background...
1600 TP, 1.25:1 rockers, 34ict carbs, lecky ignition and fuel pump, everything else stock.
The story...
i went to the rolling road, the timing got re-set... again and after a bit of fiddling we came to the conclusion there is something wrong, its idling on cylinders 3 and 4, but not 1 or 2, but when you get the revs up the other two kick in, it sometimes sounds like its missing at higher revs. so we tried a compression test on no.1 and it was very low.
And i went off to fair bank and craven in scarborough (couldn't help much since so busy but great blokes)
they gave me some workshop space to fiddle with stuff and plenty of time and assistance they probably couldn't afford with their days job list.
the timing was re-set... yet again, and the carbs accused of being the problem, not in the sense that they need setting up, but more that they have never seen a set that worked properly.
so after tweaking things enough to get me home i headed off.
through the gears it was a bit slow, and when the power is let off then put back on it gets a bit jumpy, but then smooths out.
50 mph is registering as about 3000revs,
and I'm slowly loosing the will to live...
after a short stop off for a cup of tea we thought the issue could be with the coil since its at least 30 years old, has a couple of live feeds taken off for ignition controlled gubbins (fuel cut off and pump) and its the two longer HT leads that are struggling, but numb nuts here fiddled with wires and made things stop working so i couldn't check the spark strength. i will sort out the wiring back to the right place and get it going on friday but i just want it to run properly now. any ideas or assistance would be greatly received.
The story...
