Hi all
I hope you can help, one of my hoses has corroded and fallen off but i don't know what diameter it should be (until i crawl under tha van), i'm at work and have the opportunity to nip out and get the hose, if i knew what size it is.
Right: I'll try and explain which bit it is.
If we move from the back of the bus to the front.
Heat echangers, heat exchanger connecting pipes, y pipe, large pipe runs through chassis to front, y pipe - main pipe to cab, small hose (the one i need to find the measurement for) which feeds the rear passenger compartment from the rear of the walkthrough floor.
I hope this makes sense.
