dt100
I've a couple of quesions that I'm hoping someone may be able to answer.
The van is a '71 Devon.
1. There are 4 heater levers (which I'm replacing with the billoted metal type) - the left two open the two font fresh air flaps, then the two right levers haven't the cables running to them. Should these each run to the left / right heat exchanger?
2. The bumpers have the 'rubber' step on them and the front indicators are 'low'.... but I also have a step in the cab which fits the later 'step rubbers' also. Was this set up ever origional, or have I a previous ammendment.... ie someone welded in the 'wrong' later steps (there is a fair bit of welding around the step areas, although looks well done and very solid). I found this out when ordering a new set of carpets from 'MadMatz' which although correct for the year didin't fit until they kindly exchanged them for later carpets.
My main reason for question 2 - is that when I looked up the heater lever cables they seem to be very year dependant, and now I'm basically questioning what year of van I should be ordering for.
Sorry if my questions are basic, but any help much appreciated.
