hmm - tough one - I've done a change from 1600 to 1641 and there wasn't anything obviously different between the two - apart from the casting of the cooling fins on the barrels was definitely of a lesser quality than the OG ones (rougher finish on the cooling veins e.t.c.) - maybe a picture of the barrels if you can see them through the tinware, though on that note first thing I'd check is missing tinware under the barrels themselves as this is a sign that the engine has been taken apart, but not if they have been replaced, can't recall any markings on the barrels externally either - not much use I'm afraid!
