cymrusteve
- Joined
- May 18, 2011
- Messages
- 60
- Reaction score
- 0
Finally getting around to replacing the hack of an ignition switch installed by the PO on my 71 Westy:
Managed to source replacement parts (housing, lock and ignition starter-switch)
but something doesn't seem right with the lock barrel within the cylinder.
Everything lines up when the key is in the off position, but when the key is turned clockwise, the barrel recesses about 5mm into the cylinder:
Key off:
Key turned:
You should be able to make out the recess in the above two photos.
I'm assuming this is not normal, but don't really have anything to compare it to. Posted the same question over at TheSamba.com this morning - an extra set of thoughts/comments would be welcomed.
Thanks!
Key off:
Key turned:
Thanks!
