panalvan
The indicator lights on the dash don't work no problem with the lights on the van and the hazard lights work but nothing on the dash I've checked if there's power to the bulbs there is but when plugged back into the builds nothing.what is the voltage ment to be as when I check the voltage when flashing it goes down to 10 volts then up to 12 volts as the indicators flash
