Yep, that tiny bit between the valve seats, is it worth welding as the rest is fine. The other head I've used as it was 100% fine, no cracks, replaced the one on the engine as it had cracked a lot and been repaired but didn't look too nice, had no confidence in it at all.jonboylaw said:You mean between intake and exhaust ports in the combustion chamber? I would not use them as you risk dropping a seat and causing a LOT of damage.
Good idea :mrgreen:Happystamps said:knackered cylinder heads make excellent chucks for when jacking up the car I painted mine yellow so I know they're shit and took the valves out.
