Is there an easy way to check the original spec of my van ?
Speedman
Jan 29, 2007
466
Reading
Good website, I recently bought the Spec guide book to decode my Mplate as well, it gives more detail about the codes and changes than the website (though it uses a lot of Vincent's research too.
if any one has a plate they'd like decoded send me a photo of it or write out the coding exactly as it appears (the layout is important) and I'll have a look
Steve 8)
Steve..
Wouldnt mind some help with mine as most aren't listed
on Type2
M codes--020 043 061 196
Cheers,
Snakey
No problem...
020 = speedometer and odometer in miles
043 = not sure on this one, it is on the Mplate of a 1968 Swedish Kombi I decoded the other day though
061 = Type labelling of seat mounting and identification plates for England & Irelend
196 = nothing listed for this one either
not a massive help, I'll add the codes with nothing listed to my list of unknowns :wink:
Craig
213 is 'without rubber mat in passenger compartment' UK
I have only just checked mine after 3 years ... i have been busy ..
My plate reads like this : ( as far as i can tell through the hammerite! )
02 233 115
2451 C96 042 141 191
25 5 7481 EN 2340 11
As I can't get onto the site above.. can anyone tell me what all this means ..
Whats all the other stuff other than the m codes ..
Thanks guys
Hilly
02 233 115
Thanks guys
Hilly
Hi Hilly
Speedman is your man for this send him a PM, but if you can get in the site above is pretty useful, not sure why its not working!
0 = 1970 model year
2 = type 2
233115 = Chassis number
2451 This would normally be a set of 6 digits ie 242451 would mean same colour (not sure what colour 24 is) upper and lower and 51 is dark biege leatherette interior.
C96 =
042 =
141 = heater vent into passenger compartment (rear)
191 = outer and inner under belly pans
25 5 = week 25 day 5 (Friday) of model year
7481 = temporary code
EN = Export to england
2340 = Kombi, sliding door left, RHD
11 = type 1 engine and manual gearbox
Sorry about the blanks, doing the rest from memory.
Here the codes for my westy, any chance a code guru could decifer it for me
02 107 122
517 51B
523907 D26 B67 026 507
02 4 7797 UT 2316 21
02 107 122
517 51B
Again, I would PM Speedman - a true gent and as you say a guru in this department. Alternatively I use http://www.type2.com/m-codes/" onclick="window.open(this.href);return false;
0 = model year, 1970
2 = VW type 2
107 122 = Chassis number
517 = Campmobile
51B = (could this be 518?) Campmobile with poptop roof
523907 = Campmobile paint code for Pearl White, leatherete interior
D26 = D27 I cannot find, could it be 027 Emissions compliant with californian standards?
B67 = Westfalia campmobile SO67 interior
026 = "With activated carbon container for absorbing fuel vapour"
507 = vent wings in cab doors
02 = manufactured 2nd week of model year
4 = 4th day (Thursday) of production week
7797 = unknown VW code
UT = picked up by first owner from factory in Germany, meant for US market
231 = Kombi right hand lsiding door, LHD
621 = unsure but this denotes the engine tyoe and transmission.
Hope this helps, but as I said, Speedman is the guy for a more accurate translation!
Hey Guys - any chance someone can do mine for me??
Thanks!! :D
'71 Dorma said:
02 107 122
517 51B
2 = VW type 2
517 = Campmobile
cheers dude :mrgreen:
Thanks!! :D
Thats an easy one as it is so similar to mine!! (use http://www.type2.com/m-codes/index.html" onclick="window.open(this.href);return false;)
2 = model year 1972
2 = VW type 2
070177 = chassis number
4747 = Neptune blue lower, neptune blue upper
51 = dark biege leatherette interior
A41 = Spec for UK, RHD headlights, speedo in miles
141 = heater vent to rear passenger compartment
191 = inner and outer under belly pans
48 = manufactured week 48 of model year ( I can never remember when weeks begin so won't try and work this out!)
2 = day two of manufacture yr, Tuesday
7473 = unknown code, possibly a temporary VW code
EN = built for export to England
234 = vehicle type - kombi, sliging door on left
011 = engine type - 47BHP manual transmission.
Hope this helps, again there are others who can be more accurate than me!
