Hi there -
I've been puuting up with a few knocking noises from the front of my 71 bay. The main one that's annoying me is when i wiggle the steering wheel from left to right i get a knocking noise which seems to come from the steering box.
On closer inspection if i pull on the drag link (side to side) the box knocks so i thought i'd have a go at adjusting it!
I've only every adjusted a bug one so i did it the same as that - wheels up, loosten nut, turn wheel 90 deg. then fingertip pressure until i feel it tighten up then turn 180 the other way and do the same! But, after doing this i have a tight spot in the middle of the wheel movement!!
Now i wonder if the box is knackered but have read about the shims in the lower end plate - what happens if i add or remove one of these or am i doing something wrong on the adjustment???
I have loostened it off to the point of not sticking in the middle but i am still getting the knocking noise but there is still 1-2" of freeplay and the steering is quite stiff??
I have replaced the front beam, arms, ball joints, drag link, fixed track rod etc...
I am also getting some clanking noises when hitting bumps and i don't know whether this is my shocks but one thing at a time eh!!
Cheers Dave
Cheers Dave
