Leaking oil out of breather pipe
DevonJay
Dec 13, 2015
12
Would anyone have any ideas as to why I am getting a leak out of my breather pipe.
Engine seems to be running fine.
The leak is minor leaving it's little spots and making a little mess of the tinwork.
Could this be crankcase blow by?
Jay
Sent from my SM-G928F using Tapatalk
Two things to check. Firstly make sure the pipe from the oil filler is connected to the air cleaner and that it is not obstructed. Next check the rubber "beak" is fitted to the bottom of the the metal tube, under the tinware - and that it has not gone hard with age.
I had an issue on a beetle where if you have them little k&n style breathers they get clogged up with oil blocking vent
Trikky2 there doesn't seem to be a rubber beak at the bottom of the breather tube just goes to a hole
Well there's your problem then :lol:
http://www.justkampers.com/vw-t2-bay-parties-d-une-fen-tre/t2-bay-moteur/oil-system-lubrifiants/253-260-180-rubber-boot-for-the-oil-breather-vw-beetle-1961-on-vw-t2-bay-1600cc-1961-1979.html" onclick="window.open(this.href);return false;
What's the rubber beak for?
It's a valve that controls the breather pipe air flow into the case. It prevents oil mist exiting behind the pulley.
