Hey guys, new(ish) here to the air cooled scene anyway,
really would appreciate some help.... here's the story, bought my "71 a weeke ago now, leisure battery never working o i thought i'd se what the problem was, turns out the fuse in the realy keeps blowing, so i get hold of the wiring diagrams in cornwall at the jamboree find out that one wire is conncted to the coil and another to the wrong (big) point in the alternator, sorted that, still no luck keeps blowing fuses
took the leisure battery out today, thought i'd charge it inside, topped up with de ionised water, puts on charge 3.2 volts and climbing excellent or not.... gets to about 6.7 v then the charger drops off, when the battery voltage drops to about 5.5v the charger kicks back in again until it reaches about 6.7 etc etc. you get the problem..... anyway, the leisure battery is 110ah and the charger can put out up to 5.6amps if that's any reasoning..... thanks if you read through this, lk forward to the advice
Sam
Sam
