sa-notta Member Joined Mar 18, 2018 Messages 10 Reaction score 0 Sep 22, 2018 #1 As above, I’ve got what seems to be a lighter than normal clutch pedal and it’s becoming increasingly difficult to engage gears. I haven’t even begun an investigation yet, I’m thinking a knackered clutch cable ? Thoughts ?
StuF Well-known member Joined Sep 17, 2011 Messages 2,907 Reaction score 2 Location Lincoln Sep 22, 2018 #2 tighten the wingnut on the gearbox should remove the slack in your stretched cable
sparkywig Administrator Staff member Administrator Moderator Supporting Member Joined Feb 9, 2008 Messages 12,618 Reaction score 1,300 Location mostly here, sometimes there Sep 22, 2018 #3 The cable could be stretched, adjust the tension on the wingnut so that you've got about 1/2"/12mm freeplay at the pedal. Also check that the clutch Bowden tube hasn't come away from the bracket on the gearbox.
sa-notta Member Joined Mar 18, 2018 Messages 10 Reaction score 0 Sep 22, 2018 #4 Thanks thanks, I’ll take a look when I can find the time!
