Genchy
For a while now i have had an intermittent starting problem. When i turn the ignition key the dash lights come on but there is no connection to start the motor. However sometimes it just turns no problem.
This morning it started okay, but this afternoon it wouldn't start at all until a put pressure on the wiring behind the steering column.
Has anyone else had this, is it a common problem?
Is it easy enough to remove the steering column and check the solder/connections to the ignition.
I have Haynes and John Muir so will take a look, just thought i would try you guys as you suffer the pains of VW ownership every day :lol:
Kev
Kev
