Velgreeno
- Joined
- Aug 21, 2020
- Messages
- 295
- Reaction score
- 158
Hey folks. Well as some of you know i bought a new vac distributor not long ago. Well i have just installed it now but swapped with electronic ignition and the right wires are on the right terminals Checked everything quite a few times before starting, rota arm in the way it came , no loose connections as far as i can see, the ht leads i haven't touched and they are in the same place, the distributor itself is in correctly and in there up to the neck with smooth movement for adjusting, the cap is on good and as far as i can see, thevvac pipe is on the bottom pipe of the carb amd everything is as it should be but she wont start. Turns over but no start up. What have i missed ? Cheers. .
